Shocks
Frizz423
Tennessee
Typhon 3s
I'm looking to upgrade my shocks on my typhon 3s. Any suggestions on what brand and what oil weight to run?
avogev
ArrmaForum Fan
Typhon 6s
why are the typhon ones recommended vs the other models?
Frizz423
Tennessee
Typhon 3s
Go with the 6S Typhon shocks... Keep an eye on Jenny’s... They go fast when offered.
I just got some if the 6s shocks to install on my Typhon 3s, the top caps of the shocks have a larger hole that the screw. Any tips on what to do ?
bicketybam
BickeringBam - YouTube Mega Star!
ArrmaForum Fan
New Milford, CT
BigRock 4x4, Granite, Notorious, Talion
You can use a pivot ball from the turnbuckles if you cut the flanges off. That's what I did.
You can also use nitro fuel tubing. I've done it in the past.
Frizz423
Tennessee
Typhon 3s
It looks like your caps are plastic mine are aluminum. Should the hole be the same size?
bicketybam
ArrmaForum Fan
New Milford, CT
The holes in the plastic caps are. Tiny bit smaller.
bicketybam
ArrmaForum Fan
New Milford, CT
But the tubing or balls from the turnbuckles should work still? What vehicle were those turnbuckles off of?
It's the ones from the 3s BLX trucks. In this case it's from a Granite. They will still work but with just a little bit of play.
slick2500
Will work for beer.
ArrmaForum Fan
Rapid City, SD
Outcast 6s, Typhon 3s
I used the ones out of the old shocks.
Similar threads
