I got the shocks from the outcast fronts so idk if the pistons are the same i use 40wt on rhe rear vs 80wt in front and they have the same feelThen,i tested kraton 4s but its too soft on rear...typhon 6s shoks, Kyosho Oil 500 cps 1.2mm holes in disk and original kraton 4s spring...then,what type of spring i can use for an harder setup on the rear ?
