If the stock bearings last 20 runs consider yourself lucky. Also bearings are cheap, an entire kit is like $20.Hello everyone I have an Arrma talion and on the record they say to change the ball bearings every 20 runs.
Should we do it?
Jim's Bearings are pretty good. I've had his bearings in my Outcast since December.Ok so i have to buy the fast eddy ball bearings ?
Fast Eddies, Avid-Rc, Boca, Jim's, others - there are lots of good sources of bearings.Ok so i have to buy the fast eddy ball bearings ?
That sucks I wouldn’t go there againThe dirt at my bash spot eats bearings like it's nobody's business. You should see my bearings after one bash session from there. I've literally had bearings last one pack out there. Started with a freshly rebuilt Trinity Speed Gems II Quartz, by the end of the pack the bearings were toast.
Just be prepared to do a full tear down and clean afterwards. As fsr as bearings go it depends on a few things like if you are running the stock bearings or rubber sealed bearings and how fine the sand is. The stock bearings probably won't fair to well in sand especially the fine stuff. Rubber sealed bearings will likely be okay for a while longer again it just depends on how fine the sand is. The finer the sand the more likely it is to cause bearing damage and get inside everything.Old thread, but is running on sand at a beach a bad idea, I plan on staying away from the water.
Thanks a lot for the info, maybe I'll give it a miss on my stock Talion, my Kraton has rubber sealed bearings.Just be prepared to do a full tear down and clean afterwards. As fsr as bearings go it depends on a few things like if you are running the stock bearings or rubber sealed bearings and how fine the sand is. The stock bearings probably won't fair to well in sand especially the fine stuff. Rubber sealed bearings will likely be okay for a while longer again it just depends on how fine the sand is. The finer the sand the more likely it is to cause bearing damage and get inside everything.
On the 21st run the truck self destructs so absolutely!!Hello everyone I have an Arrma talion and on the record they say to change the ball bearings every 20 runs.
Should we do it?
