So I got these tires off a member on here on the forum. These were somewhat used but are in good condition. Should I glue these up with proline CA glue I have laying around?
Here is a picture:
Here is a picture:
YepSo I got these tires off a member on here on the forum. These were somewhat used but are in good condition. Should I glue these up with proline CA glue I have laying around?
Here is a picture:
Yea maybe wipe it with some alcohol or try get some that gunk out then glue it for sureSo I got these tires off a member on here on the forum. These were somewhat used but are in good condition. Should I glue these up with proline CA glue I have laying around?
Here is a picture:
If you have a dremel, grind out a bit of that coarse area first, clean it then glue it. I've glued plenty of tires like that which ended up lasting a long time. Just check them after every run in case you need to add a bit more.So I got these tires off a member on here on the forum. These were somewhat used but are in good condition. Should I glue these up with proline CA glue I have laying around?
Here is a picture:
