Kraton Should I move from 800kv to 1100kv?
Currently reading:
Marko R1
Sydney
  1. Kraton 8S
  2. Kraton EXB
  3. Notorious
Hi guys - I'm currently running an XLX2 with 800kv (39/39) in my K8S, can I achieve a higher top speed or am I maxxed out with my gearing? Reason I ask is that & thinking about buying a 2nd motor...the 1100kv...is this considered an 'upgrade', will I see a higher top speed & is it worth it or am I burning my money :)
As a side note, I've yet to play with my timing/punch settings etc & in fact, my ESC settings are at stock standard - I do have the USB link so maybe I should play with the settings first...
Cheers!
3x9rtse
  1. Kraton 8S
  2. Mojave
  3. Notorious
  4. Senton 6s
  5. Talion
I don't know how fast you have gotten out of that combo , but with my K8S HW Max5 / 1100kv , 27t pinion , stock spur mine goes 54mph which is conservative as the motor has never seen over 146 for temp without fans . Have seen my combo with a 29t pinion and went 58- 59mph .
gotnitro
1st place
Cheers!
Might be something to consider, I wouldn't say either one is better than the other OR any type of "upgrade"... Going to 1100KV from 800KV is 10,080 RPM difference on fully charged 8s. Will it achieve that KV under load and keeps your temps in check, probably not.
SrC
RC is a lifestyle choice
Hospitality Award
Solutions
1
Queens, NYC
  1. Infraction
  2. Limitless
  3. Kraton 6s
  4. Mojave
  5. Notorious
  6. Outcast 6s
  7. Typhon 6s
^^^ +1
10K rpm's may be a small difference on paper when you consider actual running load with a 30 pound rig.:unsure:
If you compare the weight difference between the 800kv and 1100kv motor, this may tell the picture better. The heavier motor will probably be more powerful. Torque wise. Which is what you want with a 30 pound 8s rig.
First Try overdriving the spur more for better speed.
Or bump Motor timing up one notch at a time at the ESC. Checking motor temps.
Just my spin.
Marko R1
Sydney
  1. Kraton 8S
  2. Kraton EXB
  3. Notorious
Decided to stick with my 800kv / XLX2 setup!
Got this bad boy 29t Limitless spool gear to act as a spur gear for my K8S 🙂
What pinion should I run as I want more top speed than my current 39/39 setup?
Also running the Caste twin blower fan.
Raginbull74
California
  2. Outcast 8s
Use the 39t pinion and see what it does. Be sure to use the sensor wire. Have you dialed in the settings on your esc?
Marko R1
Sydney
  1. Kraton 8S
  2. Kraton EXB
  3. Notorious
That will be massive top speed gearing but I could try that - what settings do you suggest on esc? Atm it is factory stock settings but I have the usb link for it
Raginbull74
California
  2. Outcast 8s
There are a few threads on here about the xlx2 settings. There are alot of different things to mess with. If you have the B-link it makes things really easy to adjust. I could write a load on all the settings, but to get it running the basics would be power setting at full, punch control at 0% (the higher the percent the less punch on castles) and start power on Low. Those are the main ones imo. Secondary would be braking % and depending on what servo you run, up the bec power to 7.5v If your servo can take it. The things I don't mess with are motor timing, rotation and drag braking....but that's just me.
Hope that clears things up.
LibertyMKiii
Aerodynamics speed junkie
Solutions
1
Dallas TX
  1. Felony
  2. Limitless
  3. Kraton 6s
  4. Typhon 6s
My 2 cents is that the ESC is perfect out of the box.
You could play with the punch, but the castle ESC handles the timing dynamically. If it is not cogging or running too hot then leave the timing alone...
