Been there, done that.My wires today were super hot:/ and my sliper clutch broke
My wires are hot to the touchYou won't notice any difference in performance or battery life due to the connector type. I have had a similar experience to @olds97_lss with the Traxxas connector failing (though only once) and resoldering it was painful. I only have one Traxxas and it has its own batteries so not a big deal for me like him and his 30+. My 2S vehicles/batteries have XT60's and 3S and above XT90's. EC5's are a good connector as are XT150's. The only reason I wouldn't run Traxxas connectors is that they are a pain to solder. Otherwise just try and standardise as it will make your life easier in the long run
Motor esc baterry every wirehmm that shouldn't be a connector issue I would have thought. Which wires are you talking about? The ones on the battery side, ESC side or both?
Specially the connector is really hot almost uncomftable to touch
Your voltage is sagging really low. Have you tested your batteries?Motor esc baterry every wire
They are fineYour voltage is sagging really low. Have you tested your batteries?
4000mah 40c 4sYou could have a bad solder job. What battery are you using?
I’m telling you that heat is caused by voltage sag. It’s a matter of fact. You can try to deny it, but that’s the root cause. Find out why and you will know how to fix it. Could be a bad cell. Could be a bad wire. Could be a faulty mosfet. Lots of possibilities.They are fine
4000mah 40c 4s
And 7000mah 40c 3s
I don't have 30 trucks, just around that many connectors I'd have to replace when including my trucks, chargers and packs. The only thing I currently have XT90's on are some xt90/xt60/trx spider connectors I made for my charger in my car so my bashing buddies at the time could charge.You won't notice any difference in performance or battery life due to the connector type. I have had a similar experience to @olds97_lss with the Traxxas connector failing (though only once) and resoldering it was painful. I only have one Traxxas and it has its own batteries so not a big deal for me like him and his 30+. My 2S vehicles/batteries have XT60's and 3S and above XT90's. EC5's are a good connector as are XT150's. The only reason I wouldn't run Traxxas connectors is that they are a pain to solder. Otherwise just try and standardise as it will make your life easier in the long run
I have a brand new lipo and does the sameI’m telling you that heat is caused by voltage sag. It’s a matter of fact. You can try to deny it, but that’s the root cause. Find out why and you will know how to fix it. Could be a bad cell. Could be a bad wire. Could be a faulty mosfet. Lots of possibilities.
[/QUOTE
Whats voltage sag?
They are fine
4000mah 40c 4s
And 7000mah 40c 3s
