thanks for the reply. just so i'm clear, are you shimming between the bearing and the main diff gear?I have the same problem and yeah shimming helped. I also noticed that my diff cover kept loosening and that made the problem worse for sure. I have two HR aluminum diffs ready to install thou. So hopefully that will permanently fix it. ?
