Kraton Signal problems
golfr75
I have a Kraton 6s and when I am running it and release the throttle and the truck is just coasting, if I turn the wheels left or right the car continues to go. It just jumps or pulsates the throttle. It almost seems like it is getting a throttle signal from the remote. Also, sometimes when it is just sitting idle, it also starts to pulsate and jump forward a bit without any signal coming from the remote. But it especially happens when I turn it right or left. I thought it could be the throttle trim but that does not seem to fix it. Any ideas of what it could be?
Thanks in advance.
Yes, a Tactic TTX300
I have tried adjusting the throttle trim with no luck
Try centering it again and then recalibrate the ESC to reset the throttle endpoints.
ok, so I am new to this. Are there instructions on how to recalibrate the ESC in the manual?
Thanks for responding to the posts.
Yes there is. Very simple actually.
Do you have a reciver that can be swapped?
Tried everything I know, today I started looking at my servo. I replaced it with one that I had and the problem has went away. Hopefully this fixed it. I was shocked because I thought I had upgraded to a good brand. It was a Savox 1210. Do you have any recommendations on a good servo because I put the stock one back in there but it doesn't seem very strong.
Thanks again
Thanks again
Wow that is odd.. That actually is a good servo. Just one of those flukes. 1211 savox is a new one. Reefs is a good brand.
