- Notorious
So at my local big box store I came across these
Speedo Silicone Ear Plugs, White, One Size https://www.amazon.com/dp/B000F6FPCM/ref=cm_sw_r_cp_apa_i_8fEnDbNE5WJS7
I had heard of others saying it's close to the 20M weight trx fluid, but actually comparing to my Revo with 20M I would put it more in the 10M weight range. Half an ear plug is all it takes. I pushed down some in my cup with the planetary gears removed. After packing it down in order to get the cross pin blocks to fully seat I had to scrape the valleys of my sun gear, then seat the cross pins. Pack a tiny bit over the cross pins leaving plenty of room for the other output. Tighten down almost all the way, turn the drive cups a bit, tighten some more, and bam, almost feels like a locked diff, but just that little bit of give. I have two packs thru her (smooth as butter), gonna wait till I have 5 packs, then teardown and inspect how it's holding up. One 4 pack of plugs will last quite awhile I'm guessing, it's the equivalent to two containers of the trx stuff. I'll keep you guys updated. ??
