I’ve ordered both of these, but I realized that the 3 large wires that end on the motor have connectors on them, and the Max6 wires end in exposed wire. Should I just clip the connectors off the end of the motor wires and solder the esc and motor wires together?
Also, I’ve heard motor wires sometimes cannot be cut on some motors, because of motor timing, or something similar, but some motors you can cut the wires? Can the hobbystar 4092 wires be cut to fit, or cut the connectors?
I’m trying to find out if I need to go back and order some connectors for the ESC wires. Even if I do, I’m not sure what size of connector the motor has. Any advice you guys? Thanks in advance!!
