Hi all,
I've recently purchased a SkyRC e680 charger, however I can't work out the charging current rates. I've read the manual twice and watched countless Youtube videos, but can't find the answer to these problems.
For example, when charging, I've got the current set to 5.2A (for my 5200mAh lipo). But when it charges it, the current never goes above 3.3-3.4A...
And when discharging, I have the discharge current set to 2A. But when it discharges it, the current always starts at 0.4A and then eventually reduces to 0.1A...
Am I doing something wrong?
Also one more thing I've noticed, the charger charging the cells above 4.20v. I will see them go up to 4.21v or 4.22v - is this not dangerous? As a precaution, I set the TVC to 4.19v, but I'm still seeing the cells go over 4.21v...
The charger knows what the end voltage should be. Yet it remains on 99% with the cells at 4.21v/4.22v for about 15 more minutes, trickle-charging at 0.3A. Why is this? Can I just end the charge manually instead? The cells end up with 4.22v.
