Hi all. Let the questions begin. I have a skyrc gnss on my limitless. I’ve used it and has been working fine. Now it does not save your run. I use in drag mode and I usually can go to settings and records to view previous runs. Now it will record your run so you can see your pass when you hit read. But if you try to go back and view it is blank.
Any setting or reset I can do to fix this?
Thanks in advance.
Mike
Thanks in advance.
Mike
