- Thread starter
- #21
I just placed an order for a set of GRP S1 on road tires plus a few odds and ends.
Yeah some part is wrong. Looks like Kraton axels or something.So I have a question. I have typhon hubs, typhon axials, and carriers. Why do I have this gap between the hubs and the carrier? The only thing I can think is that I have the wrong axial.
Yeah I figured it out. They are Talion axials. Doh!! Set another alert for a typhon set on Jenny’s.Yeah some part is wrong. Looks like Kraton axels or something.
Starting to mock up the attachment for the front bumper. I ordered some materials to try a couple different ideas.
I ordered the materials but they won’t be here for maybe two weeks at most I think. But I’ll definitely explain what I do. You can also check out @joostin420’s build as well. His idea is awesome too. Pretty rigid in my opinion.Following this since I will use the same bumper for my Typhon Rally car build
MMX8S TP4070 2200 CM and servo doesn’t really matter. You only turn twice on a speed run ???So as I get closer to completing this build, I need to figure out what electronics to get. I’ll be picking up the flysky fs-bs6 rx but what esc, motor, and servo should I get? Not sure if I should go all out or not.
Not really doing speed runs. I mean, obviously I wanna go fast, but it isn’t the sole thing. Don’t get me wrong, I’d LOVE the mmx8s and tp motor but is it really cost effective for my application. At the bare minimum I’ll use the blx185 system. It is also the cheapest lol. I don’t know. I’m thinking of going with the mmx8s but probably a cheaper motor. Maybe a leopard 4092 or something.MMX8S TP4070 2200 CM and servo doesn’t really matter. You only turn twice on a speed run ???
Sooooooo I just bought the TP Power 4050 CM. 4070 wont fit without the stretched chassis.
I’ll end up getting the MMX 8s. Might as well do it right.
Yes 6s. 3200 kv. I’m going to pick up the x 8s whenever it comes back in stock. Should be awesome!Great choice! Which KV did you pick? I assume you are keeping it 6s?
That is pretty high KV for 6s use..... You could run that one on 3s and still have lots of power.Yes 6s. 3200 kv. I’m going to pick up the x 8s whenever it comes back in stock. Should be awesome!
my CF should be arriving today!
Yeah I’m basing it off @joostins build. Though he is running the xlx I believe.That is pretty high KV for 6s use..... You could run that one on 3s and still have lots of power.
I hope it works out for you.
