- Thread starter
- #41
Picked up a MMX 8s tonight from shadow hobbies. They have two left!
I’m using the Mugen front bumper and body mounts. Below is the three part numbers.What are you using for rear body mounts ? Also what kind of front bumper system is that?
yes you can! @joostin420 did this very option. My plan is to do the same if the above fails, however, the kydex feels really strong. It is good to have many options. Here is a link to @joostin420’s thread.That's a nice solution! I was thinking if it is possible to use the top mount that is provided with the front bumper and use some sort of spacer between the tower and the mount. Maybe not possible, I will found out tomorrow when I start my build
That's not even a question then. Turnigy Graphene Panthers are the best you can buy.Trying to decide which lipos to go with first...
Power Hobby 3s 5400 100c
https://www.powerhobby.com/powerhobby-3s-11-1v-5400mah-100c-lipo-battery-w-xt90-plug-hard-case.html
Or....
Turnigy Graphene Panthers 5000 75c
https://hobbyking.com/en_us/graphene-5000mah-3s-75c.html
They are basically the same price...
Turnigy graphenes it is!I also run turnigy graphene.
Today I made my mount in PVC ???After messing with trying to mold the kydex to the shape that I needed, I gave up! Lol! I think I just got lucky on my first mount. My next few just did not work right. I think a pliable aluminum might work a bit better for this idea or maybe I just need more experience with kydex.
Anyways, I went with @joostin420 idea but used kydex instead of CF. This was a bit easier to do but required lots of grinding away with the Dremel to get the Mugen mount to fit properly. But it works!
That looks great!!! I don’t know much about pvc. Was it easy to form?Today I made my mount in PVC ???
Typhon tower.View attachment 75874
It was really easy. Just apply some heat with a heat gun and then bend it and keep it in that position until it has cooled down a bit ??This was 4mm and it feels super sturdy.That looks great!!! I don’t know much about pvc. Was it easy to form?
That's how the kydex was but I couldn't get a good crease in it like yours. Maybe I need to learn a better technique!It was really easy. Just apply some heat with a heat gun and then bend it and keep it in that position until it has cooled down a bit ??This was 4mm and it feels super sturdy.
I had it in a vice and folded it by pressing it with a small sheat of metal to get a narrow crease. Not sure if I can explain any better ? I also did two creases, its hard to tell from my picture ??That's how the kydex was but I couldn't get a good crease in it like yours. Maybe I need to learn a better technique!
