- Infraction
- Limitless
- Mojave EXB
- Notorious
- Outcast 8s
- Outcast EXB
How many amps is that buck rated for?Got a bit of tinkering to do later and install the other 3 high cfm fans thought I'd change the stock blx 185 with these also as the stock ones are pretty poor.
Nice! It looks larger than the ones I’ve used before so I wasn’t sure if it was ultra beefy or something. Nice build. ??????Its good for 5amp so will and will take 4 x 7 watt 12v 20cfm fans with ease and as its under a fan itself the efficiency will be up ,
Hence in the video I stated I could even use this as bec if needed or run another on series or parallel.
