SLI Limitless blx 6/12s
Got a bit of tinkering to do later and install the other 3 high cfm fans thought I'd change the stock blx 185 with these also as the stock ones are pretty poor.
Its good for 5amp so will and will take 4 x 7 watt 12v 20cfm fans with ease and as its under a fan itself the efficiency will be up :),
Hence in the video I stated I could even use this as bec if needed or run another on series or parallel.
Nice! It looks larger than the ones I’ve used before so I wasn’t sure if it was ultra beefy or something. Nice build. ??????
Hey guys just a another quick update on the limitless build managed to get the quad fans tested for current draw and install two on the blx 185 esc's.
And was messing with other positions for the esc as I plan to run 2 MMx8s at some point if it doesn't destroy itself
Well that was fun unfortunately the limitless is all over the place and steering not centering correctly, power is just nuts rolled and flipped in air a few times onto the grass verge at 80mph and damaged the wing and front bumper all part of the fun so was cut short but easy repairs be back at it soon, might try another location as road surface is not the greatest but the infraction seemed planted though and that anaged 95mph with that
Think I need to make a better servo bracket and need to invest in a new go pro as I think it's dead or all my batteries are goosed from lying so Long
Just looking for some feed back on this first ever edit so a sample vid bar the poor camera skills for some reason my phone wouldn't connect but it was rather nice day tbh but 89mph 4s 105 6s with 3300mah packs on the stock blx setup full vid soon, this setup for sure will do the 111mph as requested....
Managed to put something together but my camera skill sucks but not being able to connect with the go pro quick app on my phone and lost a good bit of footage of the sky anyway and tbh they days where good but anyway this is pretty much all I have of the dual setup so far :/
Fabricated a new servo mount.
and started some battery trays to suit the graphene packs
