chrisexv6
Yesterday I noticed our Kraton making a slight whirring noise, mostly if the front end lifted off the ground (wheelie, bump in the yard, etc). I hadn't heard it before, but recently replaced the pinion with a 16 tooth Tekno. I assumed it was the pinion mesh at that point, reset it last night but I still hear it today.
The diffs seem OK...I did not tear them down, but I did check each for no slop, no clicking, no notchiness, etc.
Video attached. Might be hard to pinpoint over the metal gear noise, but my best description is the kinda "whirring" "whining" it makes under high throttle and as the wheels are spinning down if you lower the throttle amount.
Thanks.
-Chris
Thanks.
-Chris
