thegunsmith
- BigRock 4x4
So my slipper clutch came loose while I was running today about 10 minutes into my first bash since I received my warranty parts from arrma. Took it home to tear it apart because I assumed my spur gear had been torn up again. I try to tighten the slipper clutch and while I'm tightening it I can see that it only gets so tight and then the screw pops out a bit. I can keep tightening it but the screw will continue to rise up at a certain point, so it is not tightening past that point. Keep in mind at this point I am putting very little torque on the screw and I know it should be getting way tighter. I was looking at a slipper clutch maintenance set and noticed I am missing 2 of the parts shown in the set. Could these missing parts be the reason I can't tighten the slipper clutch to where it should be? Any help would be appreciated
Link to the maintenance set https://www.amainhobbies.com/arrma-3s-blx-slipper-clutch-maintenance-set-ara310882/p786313
