schmack b
- Clarksdale, MS
- BigRock 4x4
- Granite
- Kraton 6s
- Mojave
- Outcast 4s
- Typhon 3s
So I picked up a Typhon 3s blx this weekend. I pulled it out the box, checked everything out, tightened up the slipper a little, and I was off. About 5 minutes into my first run(2s) the slipper starts making a horrible sound. its still working fine just making a noise, so I pull it apart to make sure there is not a rock or something in there. Nothing in it, but with the power module out, and hitting the gas I get the noise, so its definitely coming from the slipper. So I think the bearing inside the slipper might be bad so I take it apart. Bearing is fine and nothing in it, but the screw feels weird coming out. So I put it back together and it wont tighten up. seems that the slipper pad/hubset part is stripped and not letting the pads get tight. I did not over tighten it, its just stripped. First thought is to drill and tap it to the next size up, but the thrust washer and spring wont fit over the next size. Anyone no of a fix without waiting for parts? Any one else having this issue? I want to run my new truck.
Also the spur gear on the Granite BLX and the Typhon BLX are different. I think that they would be interchangeable, but they look a little different AR310879(Granite) AR310907(Typhon). The only thing different in the two assemblies.
https://www.ebay.com/itm/Arrma-Slipper-Plate-Hub-Set-4x4-775-BLX-3S-AR310880/292880334552
this is what stripped.
