I have a problem....my slipper clutch on arrma granite blx loose all the time....every run my clutch totally loose...what should i do?
Thank you so much ?Re-assemble with some blue loctite on the threads. Let it sit after you tighten for an hour or so before you drive it.
I put a lock nut on the screw where it threads through the other slipper hub. Holding up good so far.I have a problem....my slipper clutch on arrma granite blx loose all the time....every run my clutch totally loose...what should i do?
They just did that with the V3. Get your hands on the new input gear for the rear and the slipper maintenance kit.Arrma really needs to redesign their slipper clutch system. I love my Big Rock Crew Cab it's perfect for what it is...... But the slipper clutch is the worst ever.
