Granite Slipper clutch
RC Frank
Granite
Any ideas as to why a tightened slipper clutch would make a loud noise when I hit the throttle now? Don't want to burn anything up.
MrTitanium
BigRock, Granite, Infraction, Nero
Maybe you stripped the diff gears or spur gear mesh is too tight.
Freelander
Mississauga
4x4-Mega
Mesh is too tight? Like. . . There should be a bit of play? I am stupid. But I just got an adjustable motor mount and will probably fiddlestick up meshing things. I bet there is a video for that too. . So nvm.
I like the auto censor feature on this forum. Thanks, bot!
GRC
Granite
Record the noise and we can help you better. When you hit the throttle too hard the slipper clutch is supposed to slip and makes a distinctive whining sound. If you tighten it too much, it creates too much stress and the slipper screw breaks loose. After that, the slipper clutch slips all the time and you will hear that whining sound from any kind of throttle. If it's not a whining sound, you broke something else.
RC Frank
Granite
It's definitely a grinding noise
  • Like
Reactions: GRC
GRC
Granite
I wouldn't run it then, there's a good chance you're grinding something up. Again, a video with sound would help. But it sounds like you're going to have to open it up to find out. Check for stripped teeth on the pinion, slipper clutch, spur gear, differential gear.
RC Frank
Granite
I'll put up a video later.
RC Frank
Granite
My phone only takes mp4 and I can't send the video in that format
parcou
Memphis, TN
Granite, Infraction
Google Photos loaded on Android and iPhone then get a link to the video and share the URL here....
RC Frank
Granite
I will try that sometime. I went ahead and order a new spur gear and slipper set. Just gonna try that and see where it lands me.
Create account
Log in
RC Frank Granite Slipper Clutch bolt Arrma 4x4 10
S Kraton Steel slipper clutch any better? Arrma 4x4 3
S Kraton Slipper clutch weird question Arrma 4x4 1
ArrmAh Outcast Another Slipper clutch question... Arrma 4x4 18
