Big Rock Slipper hub problems and tire problems
Caleb90
So i just ordered these off amazon https://www.amazon.com/gp/aw/d/B09L4T86TF?psc=1&ref=ppx_pop_mob_b_asin_title .
Supposed to be a 2.8 in tire but they are rubbing on the steering block. Worth trying to run or get somthing else?
Out put spline on the slipper hub for the rear diff has about had it. Replace just the hub and pads or buy a complete unit from jennys?
Tex Koder
2D , 3D Not a problem. I'll take that Challenge.
ArrmaForum Fan
Dallas, TX (USA)
  2. Infraction
  3. Kraton 6s
  4. Mojave
  5. Senton 3s
  6. Vendetta
Did you forget to put the center driveshaft spring back in.. Allowing the red slipper shaft to disengage and grind out the slipper hub?
Or did you over power the system with 4S power??
Caleb90
Nope neither, thats the out drive for the rear diff. Just has alot of run time on it.
Velodromed
One to turn, two to burn.
San Antonio, TX
  1. BigRock 4x4
  2. Granite
  3. Kraton 6s
  4. Kraton 4s
  5. Notorious
  6. Outcast 4s
  7. Typhon 3s
  8. Vorteks
  9. Voltage
  10. Infraction 4x4
Get a 4s slipper/spur off Jenny’s for 38 bucks or so. It should come with a coller to go around the rear hub. I prefer the inner race of a slipper bearing though. Much stronger. It’ll help stop ‘swelling’ which can lead to cracked rear slipper hub and stripped out inside.
Caleb90
Seems like some one would make steel hubs
52 bucks aint spending that much
