I broke a few slipepr clutches hub and now i noticed on this one the bearing was so hard to remove i had to send the edge to remove it and i saw a small crack i had the idea to hit one of the stock bearings 10x15x4 and used the inside race i call it the slipper hub saver will this work?i used a little hammer and slighly hit the top of the bearing while sitting still will it hold the slipper clutch and prevent it from spliting or its just going to snap in your opinion?
I does fit perfectly
Takes its for a run and the truck explodes ?
2 of those fkers hub sets are 40$ canadien they should just sell the rear hub alone i have 2 front hubs and 2 sliper plates that i will never use
