Granite Slipper Hub upgrade - steel pinion needed?
Okon
Germany | BW | Stuttgart
Hi folks,
i recently busted my slipper hub on one side:
So now i decided to switch the whole thing due to delivery-shortage of with ARA310948, so the steel-counterpart of ARA311034.
Not that it does anything to prevent it from happening again since the hub is still aluminum, but hey, i got a steel gear. :p
Now the gear is narrower than the plastic one, does that mean i need a steel pinion like the ARA310999 as well? Running the stock BLX 3S Setup.
Thanks in advance
Denis
Hi folks,
View attachment 176402View attachment 176403
Thanks in advance
Denis
Nope no need to change the pinion, the stock one will be just fine. Just make sure to set your gear mesh correctly and you'll be good to go.
Like @Edough13 said, you will be all set with what is there..
Break the rear section of the chassis off?.. usually that's when those hubs snap.. I've been there once..🤣
@Camaroboy383 actually i have no clue. Everthing else seems fine. Mild bashing i would say.
But thx to you both! Good to know. (y)
Definitely be sure to check the chassis well around that rear section while the motor module is out.. It usually takes a good amount flex to pop that rear hub..
You sir, get the 🏆.. the inboard side is even harder to pop ..👍..
Crazy enough man is Idk how the hell it happened. I had 1 real good wreck in the very beginning. Which in turn got that slipper assembly. Truck was running great! Just was gonna do first diff maintanance and get familiar with the rig. Thats part of what all I found. 😆🤷
