Fireteam Slow servo on new car
Kowal
HI! I just made dual motor conversion to my fireteam (brand new) and my servo feels veeereeeeeeeery slow and weak. Also it turns like 25°. If it comes to BEC, i cutted one red wire on Y cable. Any ideas?
Check your transmitter settings.
For the travel:
  • Make sure the Dual Rate (D/R) is not turned up, it will limit the travel.
  • Check to make sure you End Point Adjustments (EPA) are correct. This will also limit the travel but differently in each direction.
  • Check the Steering Trim to make sure it's centered
  • If you have a subtrim make sure that is also zeroed
For the speed:
  • Makes sure you have only one ESC powering the receiver. Your description sounds correct.
  • Basically search for "Steering" in your transmitter manual.
    • Some transmitters have Steering Servo Speed Delay (STSPD) features. This cause it to ramp to slow down and become laggy.
    • If you have a steering curve, make sure it's doing something weird.
    • If you have a Mix feature make sure it's turned off.
  • Make sure you have enough Amps supplied to the system. The ESCs should be a pretty small load
  • Check (verify) the voltage on the BEC. Get a multimeter and see what it's at.
For the travel:
For the speed:
Thank you!
