Piecejointe
I have a truggified Typhon (on not taped Trenchers that balloon quite a bit, which are barely bigger in diameter than the stock tires). It will wheelie at any speed (on asphalt, and ocasionnaly on dirt) with a pinion 15% larger than stock, on 4S. I'm running 50/50/50 oil in the diffs.
Not the talion, proportionally identical pinion, stock oil (10/100/10 afaik, so in theory even better), Katar stock tires, feels slower and doesn't wheelie ever. I understand it's a longer wheelbase, but I was at least expecting some action from a standstill. Punch setting doesn't change anything. Neither does recalibrating the ESC.
Do your Talions wheelie on 4S, or are the tires just not up to the job of putting power down (they're quite narrow, and trenchers have tons of grip compared to them on asphalt), did I somehow screw up the calibration of the RX or ESC (doubtful), do I need an even bigger pinion (why not, 15 is still reasonable)... Or is it the ballooning Trenchers that up the top speed and make it wheelie?
I'm not looking for wheelies, but the fact it feels slower is a bit depressing. I'm waiting on larger tires, but if there's anything else I might have missed, or shouldn't expect given the long wheelbase...
Thanks guys!
Thanks guys!
