SaltyLocal
Does anyone know if this charger is storage charging OK? This is my first 6s pack and i normally use two 3s. Im assuming it just takes twice as long??
It’s fine. Discharging batteries requires a lot of heat, and chargers can’t handle that without external help. If you want to discharge faster you’ll need a dedicated discharger. ISDT makes one for $80.Does anyone know if this charger is storage charging OK? This is my first 6s pack and i normally use two 3s. Im assuming it just takes twice as long??
Yes, the S2200 (and I'll assume all of Spektrum's "Smart" chargers) have three functions: Charge, Discharge, Storage.I've got an S2200 and every time I've used storage charging it was going the other way. Meaning I just used the batteries and then ran a storage charge which usually charges them up to 58-60%. I think there's an actual discharge function on that charger. I don't know about running storage charge mode while the batter is fully charged but it looks like it's running a storage discharge which should be fine.
Their discharger is great. Way better than using the charger. I have the same charger, if it’s a Spektrum smart Battery the charger charges the battery 100% then discharges it to storage level. I believe all the parameters are adjustable if you go into settings.It’s fine. Discharging batteries requires a lot of heat, and chargers can’t handle that without external help. If you want to discharge faster you’ll need a dedicated discharger. ISDT makes one for $80.
Same. I usually charge, drive and then storage charge. However, this evening i needed to charge it in order to simply dial in a servo. Sort of a waste of having to fully charge then just storage discharge it.I've got an S2200 and every time I've used storage charging it was going the other way. Meaning I just used the batteries and then ran a storage charge which usually charges them up to 58-60%. I think there's an actual discharge function on that charger. I don't know about running storage charge mode while the batter is fully charged but it looks like it's running a storage discharge which should be fine.
Indeed. I loved mine even though I only used it a handful of times. I actually sold it to him… since my ISDT K4 can discharge/storage at the same rate as just the discharger.Their discharger is great. Way better than using the charger. I have the same charger, if it’s a Spektrum smart Battery the charger charges the battery 100% then discharges it to storage level. I believe all the parameters are adjustable if you go into settings.
I hate The smart charger for discharging.
Man I just got my charger and batteries like last week. I should check the firmware. Thanks for the reminder.Same. I usually charge, drive and then storage charge. However, this evening i needed to charge it in order to simply dial in a servo. Sort of a waste of having to fully charge then just storage discharge it.
I did update to the latest charger and battery firmware. Hopefully, it'll correct any issues. I did notice once i completed the firmware updates, the charger occasionally displays an error when plugging in a battery. The only way to clear and charge is to power off than back on again.![]()
Same. I usually charge, drive and then storage charge. However, this evening i needed to charge it in order to simply dial in a servo. Sort of a waste of having to fully charge then just storage discharge it.![]()
Yep, i tried dialing in the servo with the storage discharged battery. Unfortunately, itd power up the esc but wouldnt do anything with the servo.You have me curious: why did the servo work require a fully-charged battery? For bench-testing stuff, I usually just use a battery that's at storage voltage.
The last time I was active in RC hobbies, ~5 years ago, stand-alone dischargers weren't yet a thing. I built an external resistive load, to let my charger do an "external" ~500W discharge. But the fact that you can now buy a commercial 200W discharger for $80 is pretty fantastic. That's a heck of a lot more convenient than waiting for a charger's internal 10-20W discharge function, especially with big packs.
https://www.amazon.com/ISDT-Discharger-Wireless-Capacity-Discharging/dp/B07VS2JSN9
That's really weird. I don't think I'd be comfortable driving it, with it behaving like thatYep, i tried dialing in the servo with the storage discharged battery. Unfortunately, itd power up the esc but wouldnt do anything with the servo.I checked all connections, insured polarity was accurate, and tried a few restarts, but still no servo action. Once i fully charged the same 6s lipo, the servo responded accordingly.
