Yeah, apparently what it's designed to do is not what it's capable of. Never had this in any of my older cars even after modifications, all my voltage has is a 2s and 25t pinion, both supposedly capable of being used on it, definitely NOT! Shouldn't matter if it's $200 or $700, it should be well and truly capable of what it says on the box not physically melt from said use. If not it makes me wonder about the rest and here that's honestly grounds for a refund/warranty.
Edit: looks like the motor has given up also now. Just put the 16t back in it but noticed the motor shaft was excessively hard to turn, when powered back up it started to turn but then seized up, well it was good while it lasted, shame that was only about 5 runs in less than 2 weeks.
I agree. Arrma shouldn't advertise speed numbers or performance that's unattainable without negative consequences.
In this hobby, everyone drives their RC vehicles differently and in varied environments. One person's "toughest truck" could very well end up being another person's "durability nightmare" depending on circumstances.
But having said that, manufacturers need to make sure that claims that are made throughout their advertising are easily achieved without compromising the integrity of the product they're selling. It's not good business otherwise, IMO.
Based on the failures I'm seeing in the Voltage series, it seems like a couple of areas need to be addressed:
- these vehicles need some sort of a slipper system (too much strain is being absorbed by the diff outdrives, etc.)
- they need to revamp their battery tray insert to accept all types of lipos and maybe even 7 cell Nimh packs
- add a metal motor mount plate, or in the very least add some metal threaded inserts to absorb heat (as far as I can tell the entire chassis is ruined if motor mount screw holes melt and distort)
- publish the specs for the electronics, such as esc motor limits and voltage thresholds
- improve the servo saver design
Your grievance is justified, IMO. Maybe the easiest thing for Arrma to do going forward is to redesign the box art, lol. Remove the speed claims of 25+ mph. Also, maybe they might eliminate the 25t pinion holes from the motor mount. It would be cheaper than redesigning a new chassis and/or motor plate, and would also not mislead people into believing the truck is more capable then it actually is.Agreed, too many little things that not even 10 runs in have now cost me more than I should have to be paying for, but now i'm going to need to pull apart most of the car just to replace the chassis, buy a new motor which all up will probably cost between $75-$100aud and that's just what I know of right now. I doubt that warranty will cover this even though there was no warning of this happening and I have had it for a couple of weeks now, though I think I will put in the claim since I have not used anything not made for the car. Once again it's disappointing to have this catastrophic failure so early into it's use and will probably now have to wait for a week or so due to the limited parts availability here in Australia.
Honestly it seems clear to me now that the plastic used in the construction of this model is simply not up to handling the performance claimed by Arrma and that leaves me a little worried about if the same is used in their other models. I had small issues early on that I overlooked simply because they had little effect on the use but this has really made me doubt all the reviews etc I have seen/read and considered to not be bias. The chassis melting is the last thing I would have expected to happen, even the spur and pinion still seem perfectly fine but having to now replace parts that require extensive dismantling is quite a pain. I don't understand how Arrma could not have known about this considering it took less than ten minutes for this to happen to me on dirt which I considered nowhere near as demanding as it should be capable of.
Probably a safe idea.Guess I will not be trying the 25t. It is probably like some of the other companies and is only meant to be a speed gear used for a pass or two on the road.
Motors are all pretty standard, so long as you get a 540-sized. Grab a Dynamite or Traxxas 21t or 15t and get running again.
