so apparently putting a plastic 84t on a 23t metal gear is bad.
does anyone have a gear that fits with a 23t metal gear for a rwd slash?
mines kraton 4s swapped...Dude.. All 2wd gashes come with a plastic spur and a metal pinion, nothing new.
Then why wouldn't you just simply google "slash steel spur"?mines kraton 4s swapped...
oh...Then why wouldn't you just simply google "slash steel spur"?
im just worried the gearing wont fit itGet a aluminum or soft metal. I'm using theses. These weight NOTHING compared to the other ones I have own... I'm using em on a hpi blitz. Super soft metal.. or upgrade the spur to a steel spur
Are you sure the gears are the same pitch? using different pitch gearing will shred gears I think the Kraton is .8 mod and a slash is a 48p which would cause the plastic gear the shred. make sure you have the same pitch for your gearing. And, plastic gears will shred even if pitch count is correct too!!im just worried the gearing wont fit it
the small gear is from the kraton and i think its a 23t
im not sue what that means though
the smaller gear is from the kraton as its the only one i have that fits the motorAre you sure the gears are the same pitch? using different pitch gearing will shred gears I think the Kraton is .8 mod and a slash is a 48p which would cause the plastic gear the shred. make sure you have the same pitch for your gearing. And, plastic gears will shred even if pitch count is correct too!!
