Dustin Mustangs
- Granite
It littered the inside of my gear box with its guts not to mention there is a bit of soil contamination in there too. This is on a Granite BLX. Everything seemed to be working fine before that let go. I am going to replace all 6 bearings in there and clean/regrease the gears. Should I rebuild the diff if it was working ok before the failure? Anything else I should do while it is apart?? It is the first time I have had it apart, probably 30 hours or so of relatively hard use.
