SOLD / FOUND (Socal) Outcast 8S
Status
Not open for further replies.
Niz55
Bought new RTR O8S. built and ran once in the park. Car is absolutely outstanding condition. Selling to fund a new project.
Over $2500 spent including the car.
Diff fluids 1Mill/20Mill Traxxas/ 500K
Shock fluid 50F/50R
Local pick up only.
No receiver or transmitter
Price is $1200 pick up in southern California.
Part list:
Vitavon aluminum front and rear diff cases
Vitavon aluminum front and rear bulkheads
Vitavon aluminum center transmission
Vitavon aluminum upper steering plate
Vitavon Drive Cup & Shafts Set 4mm Pins
M2C 7075 chassis
M2C suspension Hing pin front and rear ABCD
M2C front stiffener bar end
M2C MAX5 ESC plate
M2C shock pistons
EXB optional harden hing brace front and rear
EXB harden upper HD threaded hing pin
EXB CNC pivot balls
EXB aluminum shock collar front and rear
EXB red servo saver axle
EXB front motor mount support
EXB Complete Front / Rear shocks/Hardware
HR aluminum bleeder shock caps front/rear
HR aluminum pillow ball retainer kit
HR wheel nuts
Spektrum S9110BL 1/5 Speed Metal Servo
Hobbywing Max5 ESC/QS8
spektrum 1100KV motor
Xmaxx heat sink
Arrma D safe 26T pinion
5mm front and rear sway bars
Upgraded battery straps
MX57 wheels/tires
Gen ace basher series 2x4S 120C 6800mah QS8
Status
