Kraton Sockenschuss 1/8 EXB
Switzerland
  1. Felony
  2. Infraction
  3. Kraton EXB
Hi All,
Edit: Here's a link to the the images on imgur with some bonus pics hope this works.
This will be my build thread around my Kraton EXB 1/8 but it will start of as bit of a rant :mad:
I bought the EXB two weeks ago and i f***** it up pretty much from day one. To start off it inherited the Electronics from my Felony (Spektrum Smart ESC150A, SPEKTRUM FIRMA 4074). After about 20 minutes into my first bashing session i broke the shock shaft of my right front shock.
Some spares are hard to come by in europe especially in Switzerland so i decided, while the shock shafts and cups are on their way from oversees i'll fit the front shocks from my Reely Raptor to go and do some bashing today.
Blue fits the red ... NOT!
While i'm at it i also wanted to change the bushings from the steering rack into ball bearings and fit a smaller pinion. That was the plan.
which worked rather well.
The mess started when i tried to take off the motor to install the smaller pinion
Screw Head round, no way to loosen this screw so i have to take off the whole motormount.
Aaaaaaaannnnndddddddd ... i managed to fiddlestick up the next screw. So i directly drilled that one out.
Since i was mad as hell already... messing up the pinion screw and the motor shaft rounded up (sorry for the pun) my day
Now here i am beautiful day outside, three of three RCs down, spares ordered: eta three to four weeks. I'm going to bed. Good night.
jondilly1974
Speed running apprentice, motor Slayer 🤘 hoe
Solutions
1
Toledo, OH
  2. Infraction
  3. Kraton 6s
  4. Kraton EXB
  5. Senton 3s
  6. Typhon 6s
  7. Typhon 3s
Hi All,
Replace the motor mount screws with cap head screws and a small washer. Hope you have better luck going forward.
Palm Bay, FL
  1. Kraton EXB
Switzerland
  1. Felony
  2. Infraction
  3. Kraton EXB
Hey Guys, thanks for the kind words really appreciate the feedback and tips. I can definately say that i’m the one at fault here. All the screws have been tightened and secured with medium loctite by myself when first assembling the kraton. The pinion came loose multiple times during break in runs so i must have messed it up earlier.
In the meantime i went on a shoppingspree. So, coming in the next few weeks:
- all the stuff needed to rebuild the stock shocks
- shock bleeding thingy from hudy air vac something, different oils and pliers
- multiple pinions 14T, 19T, 25T
- a bash bar
- a whole set of stainless screws for the kraton
and since my wife wasn’t home and i had no governance/guidance at all i decided to pulll the trigger on a Futaba T7PRX :LOL:
i feel better now:giggle:
Monster Dork
Washington PNW
  1. Kraton EXB
Aarma claims that shock breakage at the eye end like yours comes from too much suspension droop. You might want to reduce it by a couple turns. That comes from a bulletin, I haven't experienced it yet.
Hainesy
Bedfordshire, UK
  1. Kraton EXB
  2. Senton 3s
I feel your pain; i stripped the same motor mount screw as you. I was able to recover it with a set of these broken screw extractors: https://www.amazon.co.uk/gp/product/B07V37X6M5/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
I replaced it with bigger bolts and washers: https://www.ebay.co.uk/itm/221307549544
Much more confident tightening them with a decent set of hex bits now, using blue loctite on them has held fine so far, using red loctite on the pinion gear as that *kept* loosening itself using only blue.
I've read mixed reports of swapping out all the screws with stainless - apparently the Arrma supplied screws are actually harder than SS.
Stick with it though - it's fun as hell once it's all dialled in and up and running :)
Monster Dork
Washington PNW
  1. Kraton EXB
Stainless hardware in the grades we get for little M3 screws is 300 series non-austinitic non-work hardening easy to machine steel. It is considerably softer than the good alloy steel that the usual blackened fasteners come in. I love stainless for it's corrosion prevention, but if strength is critical, use black steel. Automotive stainless, like ARP, is magnetic, heat-treated 400 series steel and is priced out of the hobby market by a fair sight. Upsizing M3 to M4 with a drill and tap is a good plan for problem spots. Careful with small taps; if you think removing a broken fastener is tough... try a broken tap.
Switzerland
  1. Felony
  2. Infraction
  3. Kraton EXB
Hey Guys,
thanks for the feedback and the kind words. So i bought a set of these
and lo and behold 10 minutes later
totally saved the motor mount and the pinion too
i then retapped all the threads to get rid of any remains of loctite. Also bought a set of M4 cylinderheads and washers for the motormount as recommended.
One huge step closer to putting the Kraton back togther. Shockshafts also arrived today, still waiting on the cups for the shocks, Oil and other stuff.
i haven't touched the shocks before the broken shaft at all so ... i don't know ... maybe i got a bad one ;)
has anyone of you upgraded the shocks? Is there an upgrade at all to the Stock EXB Shocks with 4mm shafts ? I know there's a huge thread around but some of the information seems outdated.
Switzerland
  1. Felony
  2. Infraction
  3. Kraton EXB
Today i recieved a little bit of upgrades and bling for the Kraton
Since i didn't know if the bar and skin combo would fit the RC Monster Bar i decided to cut the skin myself.
Maybe i'll order a bar and skin combo later. Let's first see how this thing holds up.
I continued to put the Kraton back together with the saved motor mount
The Stock Bumper of the EXB wouldn't fit so i need to get creative
Hacks and Bodges with a little bit of Dremel action
Finished product.
sadly i can't testdrive yet since the borrowed shocks are way too short and soft so getting on the brake means rubbing the front on the floor.
I went on with reinforcing my bash body with the good ol dry wall/shoe goo.
My second time using this method, made less of a mess this time
i hope the rest of the materials for the shocks arrives soon so i can bash that thing around and break it again. USPS doesn't seem to like me, the tracking of all the parts just says "Label Created, not yet in system" :sneaky:
Switzerland
  1. Felony
  2. Infraction
  3. Kraton EXB
Sooooooooo. The shock shafts arrived but the Arrma cups are still nowhere to be seen. I decided to pull the trigger on some Hot Racing Shock Ends and then that somehow happend :sneaky:
Gearboxcases, axle carriers and enough shock ends/caps to rebuild eight shocks
also got some 1000cst oil. Rebuilding the shock with the damaged shaft took about 5 min
i know the HR ends are not a replacement but they fit and they work.
finished product
took it out for a short bash around the woods, hit some jumps and rocks seems to be holding up
Switzerland
  1. Felony
  2. Infraction
  3. Kraton EXB
Aftermath of todays, actually my first real, bashing session.
a serious nose dive led to
which led to
i got some serious air time too sadly no video but i got rewarded the flying rearwing of valor :LOL:
Other than that i couldn't be more happy about the performance of the kraton as of now. Everything else held up very good.
I guess i need some recommendations for a new bumper (rpm?) and a new wing mount (rpm, hot racing?) what you guys prefer?
