After a lot of thinking Ive decided to sell my Notorious. It comes with four 6s Lipos. (2 Ovonic 50c 5200mah, and 2 Zeee 50c 5200mah. Always put into storage mode after use). It has a ton of upgrades and parts. A lot of them new, some used but good. The blue body is in excellent condition, just installed brand new never used Backflips and a new chassis. Diffs were recently filled with 60k front, 200k center, and 30k rear. Lots of red aluminum parts also. Spektrum STX2 system with Hexfly HX3225 servo and lot more. All you need is your own charger. With all the extra parts you will have extras for a lot of the frequently needed parts. Full list of everything included below. I have about $1500 into this not counting all the new and used parts also included. Selling for $730 shipped. Shipping to lower 48 in the US only, unless you want to pay the difference for other locations. Most likely UPS or Fedex ground. Depends on location and prices. The shipping is going to cost me over $100 so Im losing quite a bit here but Id rather someone get this and use it. If interested just PM me. Paypal only unless you live near Napa California then I might consider a meet up. Thank you!!
New/upgraded parts installed:
Brand new DBoots Backflips tires and wheels (Tires vented with wheel holes covered)
Brand New Chassis recently installed
Blue Body (in very good condition)
Stock Black body also included (good condition, no cracks)
Yeah Racing Dual Fan
New motor mount
Full Fast Eddys Bearing kit installed
Hot Racing Aluminum Diff cups (front, center, and rear)
Hot Racing Aluminum Center diff cover
Hot Racing Aluminum Steering link
GPM Red Aluminum front and rear chassis braces
GPM Red Aluminum front and rear suspension mounts
Hexfly HX3225 25kg servo
Armor Werks red aluminum solid servo mount
Tekno Shock ends
RPM front bumper
RPM front and rear A-Arms
RPM Wing mounts
Brand new T-Bone rear chassis skid just installed
Brand new rear wing with decals just installed
New parts not installed but included:
AR330230 COMPOSITE BALL CUPS (minus bumper)
AR330505 Composite steering block (One new, one with stripped screw hole)
ARA320500 Center brace mount (NEW)
AR724505 M5x5mm set screws (some new)
AR330508 95mm shock springs (NEW)
AR310498 Main input gear (NEW)
AR330379 Composite Suspension mount set (NEW)
AR310444 2 new diff gaskets
AR713009 2.5mm pin (4 NEW)
Stock Arrma front and rear A-Arms (NEW, Never used)
Stock Arrma Wing mounts (2)
RPM81642 Wing mounts (NEW)
Stock Arrma center diff brace (NEW)
A couple decal sheets (most unused)
Used parts (some used but good, some OK, see notes):
Extra set of Dboots Backflips (3 in OK condition, 1 was tore around front edge then reglued and has held up).
Original stock chassis (Straight with a few scratches)
Full Arrma stock bearing set (All good)
Stock Arrma servo (basically new)
2 T-Bone chassis skids. (One with TBR vinyl installed. Also various
vinyl pieces not used)
1 good stock rear spring, 1 that was a different size from unknown Arrma
5 stock Arrma chassis braces (all good)
2 extra receiver trays (both good)
3 stock servo mounts (all good)
4 pinion gears total (15t installed, 12t, 14t, and 16t also included) (all good)
Extra Armor Werks black aluminum sold servo mount (used but good)
AR310854 good used gearbox with stripped chassis screw hole but useable,
and another used gearbox with stripped wing mount screw hole (also useable)
Stock Arrma rear suspension mounts (both used but good)
T-Bone rear basher bumper (used but good)
Bag full of various diff parts. Cups, used center diff with good spur (not complete)
Stock Arrma shock ends (used but good)
Stock Arrma front lower rear suspension arm mounts (used but good)
AR320467 Hub nuts (4 used but good)
3 used T-Bone skid plates (all useable)
4 used but good rear wings
1 used battery tray with straps (good)
1 used bell crank (good)
Used sway bars with other steering parts (all good)
2 used RPM 81402 rear A-Arms (good but scratched)
1 used but good Arrma wing mount
2 used but good Arrma side guards
T-Bone 100931 Front bumper (used in good condition, can be installed)
2 used but good Arrma center diff covers
AR320357 Body post set, all good but might be missing some
AR330505 composite front steering block (good)
RPM front bumper (used but good)
Arrma motor mount (used with damage where pinion slipped) (can be used)
AR320500 Center brace mount (good with stripped screw hole)
AR330381 Hinge pins (1 good, 1 bent)
AR713009 Pin 2.5x16.8mm (3 used but good)
Various good body posts
Various Arrma Hardware
Stock servo arm and linkage (good)
New motor mount
Tekno Shock ends
RPM front bumper
RPM Wing mounts
