With those large OSE connectors you will be fine. Plenty of contact area going on there. That is no xt-90will the insulation affect anything if it touches alittle likw it is ? the cups are pretty deep
They are really deep, I don't think it will affect it at all. About to put some in my infraction.will the insulation affect anything if it touches alittle likw it is ? the cups are pretty deep
I know this is an older thread. But this picture is everything you don't want to do. I built milspec cables for years before becoming a Manufactuing Eng. The insulation for the wires should not be in the solder cups. Also the positive wire in the picture is a cold solder joint. The person when they soldered the wire moved the wire as it was cooling.hey guys quick question can i have some unstripped wire going into connector like this or do i need to strip it more?
