J Mitchel
- Thread starter
- #61
SOLVED! At least by a lot!
Week or two ago, I tried going to 500k in the center diff. That made a slight improvement, but nothing to write home about.
Saturday, I received the gold Hoons for the rear. I could not get fronts. Thinking that the softer compound might do the trick, I tried them. 48 degrees, sunny and dry. No joy and no difference, even once they warmed up, the rear still was all over the place.
I called two local shops and explained my situation and frustration. I went to one of the shops with the car and also showed them the video. The felt the rear diff....turned the rear wheels opposing directions and said it felt like the oil was too light or too little by feel.
I let them know I never changed the rear diff fluid and have about 5-6 hours on the car.
The only diff fluid they had was 50k.
I changed it last night...rear diff only.
Today, I ran the car...same location, same temp, mostly cloudy and it had rained overnight....the ground was wet in most places and there was even a bit of moss on patches of the parking lot.
And the car ran night and day better. Not perfect yet, but drivable and much, much, much better.
The shop said that whether by heat the fluid broke down, or there just wasn't enough of it, the inside wheel must have been spinning and not getting any power to the outside wheel, and just kicking it out in a turn. All I know, is I can use my car again.
While I still have the gold Hoons on the rear today, I will try again tomorrow with the white ones.
I also got some different video...a new Insta 360 One X2. The mount is just a thin sheetmetal strap and is way to bouncy....I will find some other ways to mount the camera, but I thought someone might enjoy anyway.
