5AFE CRACKER
- Kraton 6s
Hey team just thought I'd share this with yas. Yesterday I was out for a bash decided to do some ramp jumps everything seemed fine and was having a blast after a few hard hits and a couple kart wheels I noticed my diffs started to click but only when quick squeezing in bursts on throttle decided to call it a day and not press my luck any further to avoid any more damage. This morning when removing my rear diff to further diagnose I found both satellite pins had broke in 3 places lucky me I had just recently purchased some spares so I was able to fix no problem everything is back together and I was able to change out the fluid and added 20k in the rear. So far I have 200k centre 20k rear. I have not done the front yet I have 50k for it just have not got around to doing it yet I believe the front is still stock as it seems to be the easiest to spin. Not what I really want I'd like the power to go to the rear more to help prevent front wheel ballooning. I did also notice a small chip/piece missing from 1 of the teeth on the rear diff spur gear? It's the bigger one not sure if this happened at the same time or before I've never noticed a difference until yesterday with the clicking sound started. Should I find a replacement spur or would it be ok to run? I don't have a spare atm and it would take probably a week or so for replacement to arrive its not totally missing just a bit ground off the top on 1 tooth. I just finished rebuilding the rear diff and just don't want to do more potential damage to the diff if it would. thoughts?
