- Bozeangeles
- BigRock 4x4
- Kraton EXB
- Kraton 4s
- Notorious
- Senton 3s
- Typhon 6s
- Typhon 3s
3s batteries are cheap and quick to charge. I absolutely recommend putting a 4s esc in, too. It'll run a little better on 3s, and 4s makes is as fast as- if not faster than- the 6s typhon. The weight difference adds to the easiness of the 3s, too.Thanks for the replies, why is it more fun? Does it actually handle better? Or or is it just because its a bit slower / less powerful? Or just the physiological factor that if you break it, it’s not too much effort / cost to repair?
Thanks for the reply. Why would you say the 3S is simpler to just grab? Is it just less worry / expense of breaking it? Obviously the prep of charging the batteries etc is pretty similar?
If you had to keep only 1, which would it be?
Also, why not gear up the 6S for the speed runs? Why use the 3S? I would have thought there’d be more potential in the 6S?
It seems that a lot of people who own both seem to say the 3S is more fun. I’m just trying to figure out why that is. Is it just because lighter cars are more fun in general? Or slightly slower cars are more fun / less demanding to drive? Or is it something specifically to do with the Typhon models.
Particulairy interested in people who have owned or used both.
Thanks.
For speed runs, I found it cheap & super simple to mod the 3s. Don't forget, though, I usually have at least one or two car's worth of spare parts on hand. I like to tinker.
I can't acknowledge the "pick one" question. They're both different enough that I'm keeping both.
