I will see a big difference if I go to punch level 5 and the brakes to 100% or better factory settings; Do you know ? thanks againThe bt2000 is sold out everywhere until July
Well I had an issue with braking so I adjusted it on the controller and it works better... for the punch yes it should Bc I think it’s set to lvl 3I will see a big difference if I go to punch level 5 and the brakes to 100% or better factory settings; Do you know ? thanks again
iam new at the hobby ....what do the motor timing when i change it ?Well I had an issue with braking so I adjusted it on the controller and it works better... for the punch yes it should Bc I think it’s set to lvl 3
U can also change the motor timing too
Should help increase rpm and speediam new at the hobby ....what do the motor timing when i change it ?
He would have to update the esc to newest fw….op u can change punch settings without spektrum esc program box… also with motor timing we are almost maxed out stock there is only 1 more step u can go and i didnt see a discernible differenceShould help increase rpm and speed
What update for what?!?He would have to update the esc to newest fw….op u can change punch settings without spektrum esc program box… also with motor timing we are almost maxed out stock there is only 1 more step u can go and i didnt see a discernible difference
can you send me a video how to upgrade esc? So even with the choice that the upgrade will bring me, it is not something essential. Did I understand correctly? Thank youHe would have to update the esc to newest fw….op u can change punch settings without spektrum esc program box… also with motor timing we are almost maxed out stock there is only 1 more step u can go and i didnt see a discernible difference
U said a few posts up… “u can also change motor timing” …..well stock spektrum 100 amp esc in vorteks came with factory fw u couldnt do this…and was limited i forget which version number factory fw was…. I know that i had to update to v1.25 and that introduced being able to change motor timing, setting bec from stock and locked 6.0v to now 7.4v and braking had more steps instead of 4 to choose from u can do finer steps …. I think there were 6 steps total on v1.25What update for what?!?
Right correct i went back to factory firmware as i saw no difference in v1.25 fw as far as speed, temps, and tried motor timing. With motor timing u can only go up one step anyway… we have pretty high timing stock …. don't quote me on it but i think factory fw motor timing was “23.75” and the next and only other step u could go higher was like “26.00…. So like i said i went back to factory fw as i saw no discernible difference.can you send me a video how to upgrade esc? So even with the choice that the upgrade will bring me, it is not something essential. Did I understand correctly? Thank you
ok I trust you. I leave it as it is ! Τhanks SirU said a few posts up… “u can also change motor timing” …..well stock spektrum 100 amp esc in vorteks came with factory fw u couldnt do this…and was limited i forget which version number factory fw was…. I know that i had to update to v1.25 and that introduced being able to change motor timing, setting bec from stock and locked 6.0v to now 7.4v and braking had more steps instead of 4 to choose from u can do finer steps …. I think there were 6 steps total on v1.25
use a hobbywing progaming card
this i bought does its job perfectlyuse a hobbywing progaming card
