Limittless
- no where😗
- Infraction
- Limitless
- Kraton 8S
- Kraton 6s
- Kraton EXB
- Mojave
- Mojave EXB
- Talion
- Typhon 3s
- Typhon 6s
- Typhon TLR
- Typhon Mega
- Vendetta
- Infraction 4x4
Center drive shafts ?only hitting 79mph on my limittless with 34/34 gearing hw 1650 mmx8s running cnhl 5200mah 90c lipos 6s. Anyone know what could be holding me back?
I have this problem can you tell me how would that help?Sounds like you need to set throttle channel on radio to reverse. then switch any 2 wires on motor and recalibrate esc
This. Logs will helpThat is odd. Back of the napkin calculations should put you somewhere in the low 90s. Can you post your data log?
Castle esc needs the throttle channel reversed, or you are running the esc in reverse preset at 50%I have this problem can you tell me how would that help?
maybe I’ll do it to my rig because it got
Me so annoyed I just got a Kraton a got 3 road rigs collecting dust because I got annoyed because of this seriousy
will do thank u also when im out running this i do make sure no one is near the road or even outside i mostly run im the morning when no one is out but i am look for a good place to run still.2 other things to note:
1. That solid red line across the data tells us you have low voltage cut-off still turned on. This must be turned off for speed running in the castle link software.
2. If a dog or kid runs out into the street during your run you might kill them or at a minimum seriously injure them. Please don't run on streets with homes. Try to find a commercial area or country road with a reduced risk of danger to others.
