- ST.LOUIS
- BigRock 4x4
- Mojave
- Notorious
- Senton 6s
- Senton 3s
- Typhon 6s
@Notorious J check out my granite speedcar,vendetta towers,suspension. So petite,cute little fellor.
Now that I've finished the Vendetta, I can turn my attention back to the Granite. Learned a lot from you, @vwturbowolf and a great guy named Omar from Facebook. Vendetta's gonna need a lot of tuning when it finally hits the road. So much power but I can already tell that the suspension and alignment is going to have issues. Can't wait to give it the first real passes. For now, I'll just keep watching you guys from the sidelines. Awesome work on the stubby speedster btw@Notorious J check out my granite speedcar,vendetta towers,suspension. So petite,cute little fellor.
NO! go out in the snow.Now that I've finished the Vendetta, I can turn my attention back to the Granite. Learned a lot from you, @vwturbowolf and a great guy named Omar from Facebook. Vendetta's gonna need a lot of tuning when it finally hits the road. So much power but I can already tell that the suspension and alignment is going to have issues. Can't wait to give it the first real passes. For now, I'll just keep watching you guys from the sidelines. Awesome work on the stubby speedster btw
I'm gonna put the gps on the Kraton next time I'm at the golf course and set some 3.8 paddle tire personal bests.NO! go out in the snow.
Normal people: How fast did you go today?
Noto J: How fast did you go into the snow today?
We got close to a foot a week and a half ago and there's been squalls on and off since. Need some warm days to melt it down a bit.How much snow do you guys have? I think we have 5in here.
...I hate you lol
I got 3 easy passes at 139 on Sunday with the infraction I had just put together. Still working on getting the down force correct in the rear,hopefully this weekend I will break 150.We finally have our very own speedrun section so,
Let’s see ‘um
Post up your daily MPH and/or new PB numbers here.
I have seen this when the ramp up is too fast it peaks hard then the batteries recover slightly after the hit then they taper back offCan anyone tell me why I'm getting this hump in amps an watts???????+3mph better than normal...usely it spikes then falls..
Do you mean throttle curve,crazy to see it recover that much under 100% throttle...I keep my curve straight accross.rpms shot up during recovering...what's the most amps you've pulled with mmx6s?I've seen 208 tops.seen others in the 240s..mmx6s is amazing for such a small esc.not sure why others don't run it.great for light 1/10..I have seen this when the ramp up is too fast it peaks hard then the batteries recover slightly after the hit then they taper back off
Only other setting I've been playing with is punch ,been trying o% opposed to 70%..seams to do better with punch above 50%Do you mean throttle curve,crazy to see it recover that much under 100% throttle...I keep my curve straight accross.rpms shot up during recovering...what's the most amps you've pulled with mmx6s?I've seen 208 tops.seen others in the 240s..mmx6s is amazing for such a small esc.not sure why others don't run it.great for light 1/10..
Is that infraction mega????I got 3 easy passes at 139 on Sunday with the infraction I had just put together. Still working on getting the down force correct in the rear,hopefully this weekend I will break 150.
The mm2 is a great esc too.Do you mean throttle curve,crazy to see it recover that much under 100% throttle...I keep my curve straight accross.rpms shot up during recovering...what's the most amps you've pulled with mmx6s?I've seen 208 tops.seen others in the 240s..mmx6s is amazing for such a small esc.not sure why others don't run it.great for light 1/10..
88mph 1/10 notorious.The mm2 is a great esc too.
Hasnt got data logging but can pull alot of amps.
Ive found it a capable esc, even in a 1/8 buggy.
What was your mph for that log you posted and in which car?
I
I’ve gotten around 220 with the mmx6 escDo you mean throttle curve,crazy to see it recover that much under 100% throttle...I keep my curve straight accross.rpms shot up during recovering...what's the most amps you've pulled with mmx6s?I've seen 208 tops.seen others in the 240s..mmx6s is amazing for such a small esc.not sure why others don't run it.great for light 1/10..
Here’s one of my last logs with my vendetta.Can anyone tell me why I'm getting this hump in amps an watts???????+3mph better than normal...usely it spikes then falls..
I think somewhere around there adding a cap pack would be helpful.
Probably 240 would be max
You can see how it bounces up and down at wide open throttle.
I don’t have a 100% explanation for some of the peaks and odd graph lines but when I zoom into just that full throttle portion the average min battery draw is good.
I tend to focus on the averages at full throttle
And just looking at my ramp up on my trigger.
Windows Key + Shift + SSearch your PC for snipping tool to grab screen shots.
Would work 100% better than cell phone pics of the screen.
