Speed Runners ~ How Fast Did You Go Today?
Jerold
San Jose
  1. Limitless
Yesterday's best run.
The setup is Arrma Limitless OG (aka not V2). Changes are in bold
Stock Body​
8S - (CNHL 9500 4S) X 2​
Servo Relocation Mod/ RX relocation
Stock D-Boots and GRPs​
BEC Voltage 7.0V
Throttle D/R 50-90%
Steering D/R 50%
K-BASH
ST.LOUIS
  1. BigRock 4x4
  2. Mojave
  3. Notorious
  4. Senton 6s
  5. Senton 3s
  6. Typhon 6s
1st 4s hit with vendetta gt..ran 129 with single 65c 5000mah with vendetta body,should be able to get close to 129/4s single with this body..find out soon...
Also tried new setup in noto..xlx tp4060cm-3480kv with 27/46/13/43 on 5s.....motor sounds good above 50000rpms
TN-RC
Goshen, IN
  1. Felony
  2. Vendetta
What are your guy's thoughts on SMC DV Extreme vs CNHL Parallel Series? They are about the same price. Has anyone on here tried them both?
It is looking like the Parallel Series is right with the SRD packs performance wise, but the SRD packs are 3x the price.
LibertyMKiii
Aerodynamics speed junkie
ArrmaForum Fan
Dallas TX
  1. Felony
  2. Limitless
  3. Kraton 6s
  4. Typhon 6s
If the performance is within 1-2 percent and costs 1/3 the price that's a no brainer...
I'll probably be getting some parallel series packs.
dk10438
  1. Limitless
where did you see that the performance was that close? I read that slow mike was getting some pretty good results but not sure if I saw any direct comparisons...
but 3x the price for 5% improvement pretty much sums up racing....
Diem Turner
Yes...I have a Premium Member
Rig of the Month Winner
Wienerslider, Germany
  1. Infraction
It's much the same with rocketry. The first 95% are easy. It's those last 5% that make the difference between low earth orbit and Campbell's tomato soup on fire.
K-BASH
ST.LOUIS
  1. BigRock 4x4
  2. Mojave
  3. Notorious
  4. Senton 6s
  5. Senton 3s
  6. Typhon 6s
Mike makes ALOT of his own packs,imagine he takes the best cells out of a few packs an makes his own....so what he does an what ya get from cnhl might be night an day diffrent...mike nows his $HIT,from his custom sodering I've seen on his escz,custom sized cnhl packs with what looks like 6awg wiring.the speeds he pulls are insane,an really helped open up the world to low voltage running.. I've had good success running the smc dv packs...if ya can fit it go for heaviest,most mah packs outa the ones you named..hell just buy both..lol
chris adams
Augusta
  1. Talion
  2. Typhon 6s
  3. Typhon 3s
Finally brought the car back after a 120+ 4s run!!!
Ran 127 right before but put it in a ditch after I lost control on braking. Some idiot didn't tighten the motor slide down very good when he was putting the car back together last night.🤪
The 123 run was on cooling packs and a short run due to fear lol.
Diem Turner
  1. Infraction
Hell yeah brother!! Congratulations 💪
real_name_hidden
Bash/Break/Fix/REPEAT 🤣
ArrmaForum Fan
Hospitality Award
Missouri/Illinois
  1. Limitless
Since it was 50 degrees outside I decided to take the V1 out
Results
84mph with a old Chnl 4S none G+ series
Back to back two runs..
101mph on SMC Dv parallel “heated” had some issues desoldering…. Like the first time.
Next weekend if the weather holds out to what it currently says I will use the onyx pack for the first time.
chris adams
Augusta
  1. Talion
  2. Typhon 6s
  3. Typhon 3s
Results
My brain can't compute the image. Lol what desoldered.
LicketySplit
Space Shuttle Door Gunner
Miami, FL
  1. Limitless
  2. Outcast 6s
After a little hiatus I’m ready to go again. Got the new 4080CM 2022kv installed along with a new turnbuckle for the servo horn. I know it doesn’t look centered but I wanted the angle to be 90 degrees coming off the horn. Now it gives equal throw from left to right. Geared 34P/31S for now. I’ll start off with 3s and 4s for some shakedowns.
