Badmofreaker
- Typhon 6s
Another 157 pass,time to gear up again.We finally have our very own speedrun section so,
Let’s see ‘um
Post up your daily MPH and/or new PB numbers here.
Let’s see ‘um
Very nice,160/6s will be a nice goal to meet
Trying, only at 330 amps per side,plenty of room to gear up. Going to order some 42's and 44's for the pinions and go from there. I have a ton of 8mm but not 5mm. I'm shooting for 170 on 6s,hopefully I can make it.Very nice,160/6s will be a nice goal to meet
That's very impressive,couldn't tell what those packs are,been watching for someone to run the onyx 6s packs..not much out there on them..I'm currently about to pull trigger on 1..Trying, only at 330 amps per side,plenty of room to gear up. Going to order some 42's and 44's for the pinions and go from there. I have a ton of 8mm but not 5mm. I'm shooting for 170 on 6s,hopefully I can make it.
You won't do it!!That's very impressive,couldn't tell what those packs are,been watching for someone to run the onyx 6s packs..not much out there on them..I'm currently about to pull trigger on 1..
They are turnigy 6s,5000 mah,That's very impressive,couldn't tell what those packs are,been watching for someone to run the onyx 6s packs..not much out there on them..I'm currently about to pull trigger on 1..
I have shims in the shocks, so I don't know how to fix that if it is a problem (that lift test).If it’s not on rails then you need to do some tuning. Hard to say without looking at it. Make sure there’s as little slop as possible to start. Toe and camber need to be right also. Don’t forget the lift test. When lifting the car from the front and back make sure both tires come off the ground at the same time. If not then it can get “darty” under power.
:... How do you get a car that locked in? I have trouble keeping my car in 2-3 lanes.
I will redo my all my alignment.Practice Practice Practice. Then tune the car and system.
I turned my steering dual rate way down that helped a ton. Other's like to delay the servo response to dampen it. Figure out what you like to keep it from accepting wild steering inputs.
The other thing is spend some time on the alignment to help it track straight. A touch of toe in, 0° camber and all the caster I could get.
It tracks super straight and keeps to one lane.
You can try moving your batteries around to distribute the weight more evenly. If it’s even an issue.I have shims in the shocks, so I don't know how to fix that if it is a problem (that lift test).
When I am running 3s or 4s I have one battery in the car. Next time I run even though it will add more weight I will put an extra battery in there that is not plugged in, in the other battery tray.You can try moving your batteries around to distribute the weight more evenly. If it’s even an issue.
That’s why I made a parallel harness. Gives me less voltage sag anyways.When I am running 3s or 4s I have one battery in the car. Next time I run even though it will add more weight I will put an extra battery in there that is not plugged in, in the other battery tray.
Right now I am just running the 160a secktrum ESC so it is running 1 or run 2 in series. No need for more power since I can't use what I got.That’s why I made a parallel harness. Gives me less voltage sag anyways.
For that price I’ll stick with Saga.Not sure if y'all had seen this or not.
Castle is doing gears now:
https://www.castlecreations.com/en/pinion-gears/cc-pinion-38t-mod-1-8mm-bore-010-0065-35
Yep and saga now offers gears with 5mm set screw. I just ordered another $120 worth of gears.... Such an big expense for dual motor cars to have multiple setsFor that price I’ll stick with Saga.
Does he? That’s awesome! I just might have to place another order.Yep and saga now offers gears with 5mm set screw. I just ordered another $120 worth of gears.... Such an big expense for dual motor cars to have multiple sets
Yep. I got some last go around. 5mm grubbysDoes he? That’s awesome! I just might have to place another order.
