- TENNESSEEESSEEEEEE
- Limitless
- Mojave
- Typhon 6s
I thought it would be interesting to start a thread on TP Power motor choices as this is a common topic on the forum.
One thing to note is that a motor is excellent if it is around 90% efficient. For basher setups with light gearing, you can see RPMs around 90%+ of the advertised KV rating.
For the purposes of this list, I am posting around 78% efficiency, which is what I am finding to be a good ballpark for these motors running near their limits in a heavily loaded speed runner.
These numbers are reflected in the far right columns and may not be what you see in real-world testing, but match my data pretty closely while running a 1/7 scale at 99 mph on 2s and 3s around 124 mph. (both with parallel battery setups of 12-16aH)
In this scenario, I estimate around 3.4v per cell under a heavy 400-600 amp load.
Motor | Wind | KV | Volts | Amps | Watts | Max RPM | Weight | Motor KV under load at 78% efficiency | Multiplied by load voltage | 2s | 3s | 4s | 6s | 8s |
TP4060 | 2y | 2620 | 19.6 | 327 | 6200 | 50k | 455g | 2043.6 | 13,896 | 20,845 | 27,793 | 41,689 | 55,586 | |
TP4060 | 3y | 1750 | 29 | 213 | 6200 | 50k | 455g | 1365 | 9,282 | 13,923 | 18,564 | 27,846 | 37,128 | |
TP4060 | 4y | 1350 | 38.4 | 163 | 6200 | 50k | 455g | 1053 | 7,160 | 10,741 | 14,321 | 21,481 | 28,642 | |
TP4060 | 3d | 3210 | 15.6 | 413 | 6200 | 50k | 455g | 2503.8 | 17,026 | 25,539 | 34,052 | 51,078 | 68,103 | |
TP4060 | 4d | 2450 | 20.5 | 310 | 6200 | 50k | 455g | 1911 | 12,995 | 19,492 | 25,990 | 38,984 | 51,979 | |
TP4060 | 5d | 1950 | 25.6 | 248 | 6200 | 50k | 455g | 1521 | 10,343 | 15,514 | 20,686 | 31,028 | 41,371 | |
TP4060 | 6d | 1650 | 30.8 | 207 | 6200 | 50k | 455g | 1287 | 8,752 | 13,127 | 17,503 | 26,255 | 35,006 | |
TP4060 | 7d | 1380 | 26 | 172 | 6200 | 50k | 455g | 1076.4 | 7,320 | 10,979 | 14,639 | 21,959 | 29,278 | |
TP4070 | 2y | 2250 | 22.7 | 300 | 7600 | 50k | 505g | 1755 | 11,934 | 17,901 | 23,868 | 35,802 | 47,736 | |
TP4070 | 3y | 1520 | 34.7 | 230 | 7601 | 50k | 505g | 1185.6 | 8,062 | 12,093 | 16,124 | 24,186 | 32,248 | |
TP4070 | 4y | 1090 | 45.8 | 182 | 7602 | 50k | 505g | 850.2 | 5,781 | 8,672 | 11,563 | 17,344 | 23,125 | |
TP4070 | 2d | 4150 | 12.1 | 625 | 7603 | 50k | 505g | 3237 | 22,012 | 33,017 | 44,023 | 66,035 | 88,046 | |
TP4070 | 3d | 2700 | 18.5 | 375 | 7604 | 50k | 505g | 2106 | 14,321 | 21,481 | 28,642 | 42,962 | 57,283 | |
TP4070 | 4d | 2080 | 24 | 300 | 7605 | 50k | 505g | 1622.4 | 11,032 | 16,548 | 22,065 | 33,097 | 44,129 | |
TP4070 | 5d | 1700 | 30.3 | 277 | 7606 | 50k | 505g | 1326 | 9,017 | 13,525 | 18,034 | 27,050 | 36,067 | |
TP4070 | 6d | 1400 | 36.7 | 227 | 7607 | 50k | 505g | 1092 | 7,426 | 11,138 | 14,851 | 22,277 | 29,702 | |
TP4070-CM | 3d | 3200 | 23.5 | 382 | 9000 | 75k | 640g | 2496 | 16,973 | 25,459 | 33,946 | 50,918 | 67,891 | |
TP4070-CM | 4d | 2200 | 34 | 264 | 9000 | 75k | 640g | 1716 | 11,669 | 17,503 | 23,338 | 35,006 | 46,675 | |
TP4070-SVM | 3Y | 1650 | 44.2 | 214 | 9500 | 73k | 640g | 1287 | 8,752 | 13,127 | 17,503 | 26,255 | 35,006 | |
TP4070-SVM | 3D | 2940 | 24.8 | 383 | 9500 | 73k | 640g | 2293.2 | 15,594 | 23,391 | 31,188 | 46,781 | 62,375 | |
TP4070-SVM | 4D | 2240 | 32.8 | 289 | 9500 | 73k | 640g | 1747.2 | 11,881 | 17,821 | 23,762 | 35,643 | 47,524 | |
TP4070-SVM | 5D | 1830 | 39.8 | 238 | 9500 | 73k | 640g | 1427.4 | 9,706 | 14,559 | 19,413 | 29,119 | 38,825 | |
TP4080-CM | d | 2022 | 34 | 324 | 11000 | 68k | 700g | 1577.16 | 10,725 | 16,087 | 21,449 | 32,174 | 42,899 | |
TP4080-CM | d | 1330 | 51 | 215 | 11000 | 68k | 700g | 1037.4 | 7,054 | 10,581 | 14,109 | 21,163 | 28,217 | |
TP4080-CM | y | 2350 | 8s | 11000 | 68k | 700g | 1833 | 12,464 | 18,697 | 24,929 | 37,393 | 49,858 | ||
TP4080-CM | y | 2250 | 8s | 11000 | 68k | 700g | 1755 | 11,934 | 17,901 | 23,868 | 35,802 | 47,736 | ||
TP4080-CM | y | 2100 | 8s | 11000 | 68k | 700g | 1638 | 11,138 | 16,708 | 22,277 | 33,415 | 44,554 | ||
TP4080-CM | d | 2700 | 25.2 | 436 | 11000 | 68k | 700g | 2106 | 14,321 | 21,481 | 28,642 | 42,962 | 57,283 |
