- Granite
- Notorious
What started off as a good run at the skate park today ended in disaster.
My second big send trying to clear the utility pole and my throttle cuts out at the apex of the jump! All I could do is watch as she tumbled back to earth from around 30ft up or better. Landed upside down of course
I'm too pissed off to tear into it and check out the damage right now but I gotta hand it to m2c..speed chassis appears to be straight and in one piece and everything seems to be still attached. At the least tho my shock towers are both bent and I just switched em out too.
I set her on the picnic table and turned the esc off and back on. No start up chime..the fans run..steering runs..nothing else. Temps were fine still cool enough to touch with your fingers and not even be hot. Motor wires are plugged in/still attached. Tried a different pack..same thing. Checked the voltage on the packs that were in it when I got home... 4.10v across-the-board..
So what's the general recommendation for escs using stock power? Max 8 or Corally esc? I don't need more performance than stock just need something reliable that won't die at literally the worst possible moment.
