How did you like the AVC in that car? Is it worth it?
Did you figure a way out of this with the 6100at? Just landed my kraton 6s and went to swap to realize it doesn't fit, now im stuck with the 6100t and dx5c and no way to mount it? Help.Trust me. The new receiver doesn’t fit. I had to put a traxxas receiver box and move the battery tray back so it would fit.
On another note, does AVC slow the car down? It seems since I swapped out the stock receiver and transmitter, that it is a little slower then it was with the stock. I made sure I calibrated the receiver correctly during the bind process. Is there anything else I should do to make sure I get the most out of my Mojave?
I thought for those to work properly they need to be face up. Does the avc work properly with it like that?harv666 - I have the DX5C and the SR6100AT DSMR 6-Channel AVC Telemetry Surface Receiver and instead of how jkflow has his installed, I did it the other way on my #v3 #KRATON and had no issues what so ever! Its a tight fit but it does fit, see below:
