RCKYE99
- Kraton 6s
Hey! so quick question i think i can post this on here at least i hope so i have this bundle https://www.spektrumrc.com/Products/Default.aspx?ProdID=SPMXPS6 it comes with the 2 spektrum 5000mah 3s 50c lipos and the spektrum dual 100 watt charger how much amps can i charge these batteries at i have acceses to each amp so each side of the battery can go up to 25 amps but it will only let me go to 12 on each of the batteries is that okay if i charge them both at 12 amps each i did that because i thought well the charger can charge up to like 20 amps per battery i think but if it limits it to 12 each i thought that meant that i can do that because its smart tech or should i lower it and also the longer you charge it the amp goes down auto so is it ok or not should i charge them at a lower amp or is 12 fine sorry for the horrible grammar and spelling i just did this in a rush
