blakeaowen15
On my 6s I have 2 spektrum 3s that I run, and the lvc kicks on when there’s 3.8 V per cell or 33% power left in the battery, why does this happen, how do I change this?
This right here, it is also looking at the voltage real time.LVC uses overall battery voltage, not voltage per cell. Because of this, LVC is set a bit high, just in case one cell is very low due to imbalance. Otherwise, you might accidentally drain a cell below safe limits
