- Infraction
Hey all, hopefully this is the right forum, forgive me if not. I'm still new to the site. And new to Arrma and LiPOS in general. I'm hoping someone out there has run into this issue and knows what's up. I'm feeling kind of down on Spektrum at the moment.
I've purchased the S2200 charger and a couple of batteries. It was this bundle specifically I picked up at the same time I purchased an Arrma Infraction v2.
All is good with those. I've since purchased 6 more batteries. Of those 6, 2 have had this problem where storage charging doesn't complete. It gets pretty close then the amps drop way down .1A and then it eventually times out.
I opened a ticket with Horizon Hobby and they replaced the one battery but I just purchased two of these and one the of the batteries is doing the same as the other one.
I should note, I've updated the version on the charger and I've updated both batteries. Spektrum has this thing that you can update batteries directly from the charger which is what I have done. Odd thing is that once you update them, you can continually update them over and over again. It's like there isn't a flag that gets set in the battery letting the charger know that it has the latest update.
Anyways, these batteries have 0 cycles, no fault records but one them will not storage charge to completion. (~60%) It gets to about ~56% then the amps peter way down and it doesn't complete.
I was hoping someone out there has had this problem and fixed it.
This thread isn't a thread to bash Spektrum and I understand why people use other brands and systems and I'm contemplating switching myself but I'm new and the idea of all the smart stuff working is pretty appealing honestly. It's nice getting telemetry info, simple charging, storage charging and having means to set defaults within the battery it's self like charging at a 2c rate and all that.
Thanks!
Lalo
Thanks!
Lalo
