I have the Spektrum s2100 and I need to update the charger so I will be able to use the G2 batteries. Does anyone know of a different cable I could purchase or does anyone have this cable that I could borrow or buy? Thank you!
Right......also to dizzle I also thought about this and was actually going to make one but I don't think it works like that, there is some kind of board inside the USB part that talks to the program on the computer.... And I don't think I would chance it with the charger too expensive to be messing with a cheap A## cable plus they're kind of finicky to update as it is. (Had To find certain drivers for the last update, because the driver's horizon had on the website wouldn't work) so I would just spend the seven or eight dollars and get the one from Amazon imoSpektrum licensed the iSDT technology, not just copy. Yes they are identical, just wasn't sure if they didn't 'lock' their brand with some sort of ID in the cable. Looks like it works just fin and good find!
Hey! If you happen to have a FTDI dongle laying around and you can get a 4 pole 3.5 cable off amazon to sacrifice, you can use the instructions in this video to hack together your own update cable! I used this method to update my own S2100 charger, so I can confirm it worksI have the Spektrum s2100 and I need to update the charger so I will be able to use the G2 batteries. Does anyone know of a different cable I could purchase or does anyone have this cable that I could borrow or buy? Thank you!
Oh so this method does work huh? I didn't think it did because it looked like it was for the older ftdi chargers and firmware. Thought it was a different interface altogether. Cool beansHey! If you happen to have a FTDI dongle laying around and you can get a 4 pole 3.5 cable off amazon to sacrifice, you can use the instructions in this video to hack together your own update cable! I used this method to update my own S2100 charger, so I can confirm it works
You could buy a FTDI bridge and cut up that cable to make a DIY update cable, though that'll probably end up costing more....I don't have a "dongle" laying around so my only option is to return this cable when it arrives and just wait for the real cable?
Yup, it's just a plain ol' UART interface! The one twist is that the 3rd segment from the base of the plug is Data Ready aka Clear to Send rather than +5vOh so this method does work huh? I didn't think it did because it looked like it was for the older ftdi chargers and firmware. Thought it was a different interface altogether. Cool beans
Oh no! Lol I don't think that one will work I will link the one that I got off of Amazon to you in a private message there's some kind of electronics inside the little part where it says " "isdt" meaning I don't think it can be just a regular USB a and a headphone jack. But who knows I'm going to link you anyway
