Scott_in_FL
So I'm installing a Firma 150 ESC into a Kraton EXB and the programming card is not showing all of the programming fields listed in the manual. For example, the third field is supposed to be LVC cutoff, but the card does not seem to be able to access that. Other fields are missing as well. I think the card sees 7 fields, but the manual shows 12.
Has anyone else seen this issue? What's the fix?
Alternatively, the manual programming also seems confusing from the book. What's the easy way to get into these fields to make changes?
And I should be putting LVC to at least 3.4V, correct (that's the highest setting available -- the default is something like 2.8v)?
